  3. What the functionality of form attribute "?basename"
  • Subscribers 152
  • Views 2248
JamesJames
JamesJames over 2 years ago
I'm just curious the functionality of "?basename" of a form that created by "hiCreateAppform" or "hiCreateLayoutForm", can anyone explain this with some example code? I would be much appreciate.
James
    James,
    I've never used ?baseName in the last 30 years (I'd never even noticed its existence!).
    As far as I can tell, it's useful if you use hiStoreFormLocation - the form location for all forms with the same baseName is then stored. This is used by Options→Save Session in the CIW (which I think pretty much nobody uses) so that you can restore form locations in the next session by using virtuoso -restore sessionFile. The baseName is then useful for the situation when you have multiple uniquely generated forms (e.g. with ?name gensym(...) to ensure you can have more than one at once) - the location information can be stored for a common base. If you don't use ?baseName it would just store the location for the form symbol.
    The documentation is pretty terrible on this argument - I'll request it is improved. I might have got the above wrong, but from a quick look through the code I think that's what it's for!
  • JamesJames
    JamesJames over 2 years ago in reply to Andrew Beckett
    Thanks Andrew, thanks share your information.
  • AH202408041425
    AH202408041425 over 2 years ago
    The ?basename functionality in a form created by hiCreateAppform or hiCreateLayoutForm is used to retrieve the base name of the form. This is typically useful when you need to access or manipulate the form's properties or methods dynamically.
    Here's a simple example to illustrate how ?basename works:
    // Assuming you have created a form using hiCreateAppform
    var myForm = hiCreateAppform("myFormName", {
    // form properties and configurations
    // Use ?basename to get the base name of the form
    var baseName = myForm.?basename;
    // Example of using the base name in a function
    function displayFormBaseName(form) {
    console.log("The base name of the form is: " + form.?basename);
    displayFormBaseName(myForm);
  • skillUser
    skillUser over 2 years ago in reply to AH202408041425
    I'm sorry but the above is confusing and misleading: 'var' and 'function' are not SKILL commands, and the syntax that you have used is not SKILL either - what language is this supposed to be, and how would it be used with a SKILL-based form?
    Best regards,
    Lawrence
    Andrew Beckett over 2 years ago in reply to skillUser
    Lawrence,
    I’d ignore it as it looks as if it was generated by chatGPT or similar. The comment characters are also wrong and it is nonsense…
    I do wonder what the point of answering questions like this is!
