  3. How to add parallel lines to the created bus line
  • Views 4869
alaylayla
alaylayla over 2 years ago
How to add parallel lines to the created bus line, this kind of bus line has bends and relayers, and it is not easy to copy parallel but not short lines
  • RobMan
    RobMan over 2 years ago +1
    The question isn't entirely clear: It sounds like you have an existing bus and you want to add (bit) wires to the route. The 'Copy Route' functionality would be suitable... Copy Route: Eases Routing…
  • RobMan
    Copy Route: Eases Routing of Large Buses and Uses Reference Wire Topology (cadence.com)
    Virtuoso Interactive and Assisted Routing User Guide -- Copy Route Form (cadence.com)
