  3. ADE Assembler Output CSV export using SKILL - Database doesn...
  • Views 1058
ADE Assembler Output CSV export using SKILL - Database doesn't update after finished simulation
A Berwald
A Berwald over 2 years ago
Hi there,
I am working on a SKILL based tool to easily export certain ADE Assembler outputs as a CSV table, which are then automatically validated using a Python script.
Unfortunately, the code only works after pressing the "Plot all" button. As this extra step is annoying and I don't want to open ViVA, I'm asking for help.
It seems that the database used by my code won't be updated without pressing the "Plot all" button...
I'm currently using the following code section:
histories = axlGetHistoryOutputs(session history_entry ?testName test_name)
data_to_export = nil
foreach(history histories
    println(history~>uniqueName)
    foreach(output history
        when( output~>uniqueName==maeGetVar("xxx_EXPRESSION")
            if( getq( output signal) then
                data_to_export = VT( getq( output signal))
                ;println("xxx_EXPRESSION is a time signal.")
            else if( getq( output expression) then
                data_to_export = eval( getq( output expression))
                ;println("xxx_EXPRESSION is an expression.")
                else
                    println("Error: xxx_EXPRESSION not allowed.")
                    return()
                );if
            );if
        );when
    );foreach
);foreach
if(data_to_export then
    unless( outfile_name = maeGetVar( "xxx_FILENAME" ) outfile_name="dummy_name")
    csv_file_path = sprintf(nil, "./xxx/%s.csv", outfile_name)
    awvSaveToCSV(data_to_export csv_file_path)
else
    println("Error: xxx_EXPRESSION not found...")
    return()
);if
Best regards and thanks for your help!
Alex
