  3. SKILL recursion depth
  • Views 6287
PC20240802164
PC20240802164 over 2 years ago
I am trying to create a function that traverses a table containing various types of data like forms, treestructs and other(meaning the user) types to save and load state of a SKILL GUI application. Our plan is to create a SKILL table that contains the form struct and to use sevWriteTable to dump XML. But, it is not parsing the user defined types, so we had to create our own function for creating a table which is suitable for sevWriteTable. However, I keep running into recursion stack overflow issues. I tested out with this procedure:
procedure(test(i)
prog(()
when(i == 10 return())
printf("%d\n" i)
test(i+1)
and the recursion stack error happens when the value of i is -30 ie when the tree is 40 levels deep. Anyone has any idea how to resolve this issue?
    Well, that code doesn't hit a stack overflow until you hit a bit over 4000 nested function calls (if I increase the I==10 part), so I'm not really sure what sharing that code is telling me? Whilst use of recursion is a common paradigm in LISP variants such as Scheme for all sorts of things (including iteration over lists), it's used in SKILL more for things where the data you're processing is hierarchical - and there it's unusual to hit the stack limits.
    What structured data do you have with trees that are more than 40 levels deep?
    Also, sevWriteTable is specifically intended for writing out XML for ADE - it's not really intended as a general purpose XML writer.
    I guess what I'm asking here is for more information as to what your data looks like and what the actual code is. If you can't share that here, I suggest you contact customer support (submit a support case after logging in).
  • mbracht
    mbracht over 2 years ago in reply to Andrew Beckett
