  3. Format text output on the DBox
  • Views 5231
Martinsh
Martinsh over 2 years ago
I'd like to create a format text output on a DBox created by hiDisplayUserDBox() function. The skill code is as following.  What I want is "Word1" and "LongWord1", "Word2" and "LongWord2", "Word3“ and "LongWord3" are aligned virtically. But they don't. Why? And how to make that?
line1 = lsprintf("%-20s %-20s %-20s\n" "Word1" "Word2" "Word3")
line2 = lsprintf("%-20s %-20s %-20s\n" "LongWord1" "LongWord2" "LongWord3")
outMessage = strcat(line1 line2)
hiDisplayUserDBox(
?name 'dBox
?dboxBanner "Format output test"
?dboxText outMessage
?dialogType hicQuestionDialog
?buttons '(Cancel)
Thanks!
Martin
    Martin,
    This is because the font used has a variable width, so alignment is rather difficult just by padding with spaces.
    You could add some simple HTML tags around the message:
    outMessage = strcat("<pre>" line1 line2 "</pre>")
    Which would give you:
    (note that the <pre> tag has caused it to use a monospaced font).
  • Martinsh
    Martinsh over 2 years ago in reply to Andrew Beckett
    Andrew,
    It works well. Thanks!
    Martin
