  3. Problem of find files with ipc command
  • Views 5345
Martinsh
Martinsh over 2 years ago
Skill code to find and print the files with name that matches *.cdslck* in the current directory:
findCmd = "find . -name '*.cdslck*' -print"
cid1 = ipcBeginProcess(findCmd)
;ipcWaitForProcess(cid1)
ipcWait(cid1)
strOut = ipcReadProcess(cid1)
println(strOut)
After ipcBeginProcess() command, if ipcWaitForProcess(cid1) command is used, nothing is read out, strOut="".
If ipcWait(cid1) is used, the read out string is correct. But if too many files are found, the string read out is not completed. In my case, the files after the 74 are discarded.
Question1, what's the difference between functions ipcWait() and ipcWaitForProcess()? I can't find it from the skill manual.
Question2, Why the read out string is not complete with ipcReadProcess() after ipcWait() when the output string is long enough? How to solve this problem?
Best Regards,
Martin
    Martin,
    First of all, I'd suggest using "clsAdminTool -ale ." instead of just using a find - it gives a bit more information.
    • ipcWaitForProcess() waits for a process to start up and be ready to communicate - in other words, it's been launched by the IPC infrastructure.
    • ipcWait() waits for it to complete.
    ipcReadProcess() doesn't guarantee to read the entire output in one go. You might need multiple ipcReadProcess() calls. From the documentation:
    Reads data from the child process stdout channel, allowing the
    developer to specify a time, in seconds, beyond which the read
    operation must not block. It only reads 4096 bytes for each call.
    You might (therefore) need a loop to read the data:
    ipcWait(cid1)
    while(strOut=ipcReadProcess(cid1)
      println(strOut)
    should do it. Note that if you use ipcReadProcess()
  • Martinsh
    Martinsh over 2 years ago in reply to Andrew Beckett
    Thanks Andrew. It works!
    Martin
