  3. how to extract the histogram after performing monte car...
  • Views 4399
how to extract the histogram after performing monte carlo
TZ20240722725
TZ20240722725 over 2 years ago
After running a Monte Carlo simulation, you can save the OCN file. Later, you can directly load the OCN file to perform similar operations. However, while you can manually bring up the histogram of simulation results, how can you obtain the corresponding histogram when using the OCN file?
