  3. How do I modify the ".cdsenv" file to turn off the Toggle...
  • Views 1293
How do I modify the ".cdsenv" file to turn off the Toggle Enter Form notification?
Brad7086
Brad7086 over 2 years ago
How do I modify the ".cdsenv" file to turn off the Toggle Enter Form notification? or Use the API:envSetVal
Toggle Enter Form:
hiToggleEnterForm(),normal bound F3 Key,will show or hide the form associated with an active enter function
if thatt enterfunction has an associated form.
Do you wish to see this dialog again when no enterfunction is active or no form exists to toogle?
I know that this notification will not appear again after pressing the "no" button. But I hope that every time I restart virtuoso, this notification will not pop up.
TKS All!
    This is not actually controlled via a cdsenv var, but by an (undocumented) SKILL variable. I've filed a change request, CCR 3036893, to either document this or get it changed to a cdsenv variable (and have that documented instead).
    I can't find any requests for this in the past, interestingly.
