  3. dbOpenPanicCellView does not work in 'w' mode correctly...
  • Views 3270
shane park
shane park over 2 years ago
Hello, I am sangyeon park.
I am using a virtuoso version 6.1.7 (or 6.1.8) and has used the command 'dbOpenPanicCellView' for a long time when I create some cells.
But, suddenly, this program does not work well, and I figured out that 'dbOpenPanicCellView' command with 'w' t_mode worked wired.
As I know, If the cell veiw does not exist, it is creaded, but It doesn't. It works only the cell exist.
I can share the message fro CIW when I used that command.
WARNING* (DB-270211): dbOpenCellViewByType: Cannot open cellview 'SIM_SHANE/cont2vdd/schematic' in 'w' mode because it does not exist or viewTypeName required to create a new cellview is not specified. Ensure that the cellview exists or to create a new cellview by specifying viewTypeName. Valid values for viewTypeName are "netlist", "schematic", "schematicSymbol" and "maskLayout
I am trying to resolve this issure finding various site. but I coudn't
Please help me
Thank you.
    This makes no sense - why would you use dbOpenPanicCellView in "w" mode? The whole point of this function is to allow you to open the data which was saved automatically when a crash occurred - so that you can recover it. If you have unsaved edits then (if possible) Virtuoso will save a panic cellView and leave a message such as this in the terminal:
    A panic file has been created for cellview 'mylib/testpanic/layout' at:
    (/export/home/myuser/support/playGPDK45/mylib/testpanic/layout/layout.oa-)
    To open the cellview with the recovered data:
    cellview = dbOpenPanicCellView("mylib" "testpanic" "layout")
    Panic files have been created for cellviews that were opened in edit mode.
    For details on these panic files, see
    '/export/home/myuser/panic.log.lnx-myuser-76.116844'
    If you open it with SKILL, you can then open it in the editor and look at it. If you were to open this in "w" mode, it would erase the contents which rather defeats the point of having saved the panic data!)
    It sounds as if you might be trying to misuse this function to open a new cellView. You should use dbOpenCellViewByType instead:
    cv=dbOpenCellViewByType("mylib" "mycell" "schematic" "schematic" "w")
    (the fourth argument is the viewType you want to create, e.g. schematic, maskLayout etc).
  • shane park
    shane park over 2 years ago in reply to Andrew Beckett
    I has used 'dbOpenCellViewByType' beacause I am developing some program using skill language for CIW, so I don't want to open editor, actually.
    I want create a new cellview no matter the file existence.
    I has used the command like below,
    cv_contvdd   = dbOpenCellViewByType(LibName center_Name   "schematic" nil "w")
    but, I realized that I should put "schematic" instead nil in that code, and It works very well. Slight smile
    ( Honestly, In the past, even I put it as 'nil' It had worked, but not now.)
    Thanks a lot.
    Sangyeon park.
    Andrew Beckett over 2 years ago in reply to shane park
    Sangyeon,
    I realised you were trying to do this batch and not open the editor - my point was that dbOpenPanicCellView was not the right API to be using.
    With dbOpenCellViewByType, the fourth argument can be nil if and only if the cellView already exists. In that case, it already knows what the viewType of the cellView is. If the cellView does not exist already (on disk) then you must tell it the viewType (this has been the case since the function was introduced in 4.4 (in 1996)).
