  3. How to disable one radiofield when the other radiofield...
  • Views 5065
How to disable one radiofield when the other radiofield is selected?
swathiba24
swathiba24 over 2 years ago
For example: When we have two radiofields ("Yes", "No")using hiCreateRadiofield() , When "Yes", "No" Radiofield should be disabled
RadioField=hiCreateRadioField(
?name 'netlists
?prompt ""
?choices list("Yes" "No")
?value "Cell View"
?enabled t
  • p94todorov
    p94todorov over 2 years ago
    You can toggle a field editability/visibility by using the value of one field to determine the condition in the other, by specifying it as a string expression. Assuming you add your fields to some form assigned to variable formVar it should look something like this:
    RadioField1=hiCreateRadioField(
    ?name 'addMetal
    ?prompt "Add Metal"
    ?value "Yes"
    RadioField2=hiCreateRadioField(
    ?name 'metalLayer
    ?prompt "Metal layer"
    ?choices list("M1" "M2" "M3" "M4" "M5")
    ?value "M1"
    ?enabled "formVar~>RadioField1~>value == \"Yes\""
    ?editable "formVar~>RadioField1~>value == \"Yes\""
    Petar
    Andrew Beckett over 2 years ago in reply to p94todorov
    Sadly Petar's proposed approach won't work - there are two issues:
    1. There's no ?editable argument for radio fields
    2. ?enabled doesn't take a string (callback) expression - the value has to be t or nil (it's not like CDF, where the editable and display fields are callbacks).
    In the original post too, the value for the radio field wasn't one of the choices which wasn't correct.
    Anyway, this can be solved by a callback on the first radio field:
    ?name 'addMetal
    ?prompt "Add Metal"
    ?value "Yes"
    ?callback list("MyForm->metalLayer->enabled=MyForm->addMetal->value==\"Yes\"")
    ?name 'metalLayer
    ?value "M1"
    ;?enabled "formVar~>RadioField1~>value == \"Yes\""
    ;?editable "formVar~>RadioField1~>value == \"Yes\""
    hiCreateLayoutForm(
      'MyForm
      "My Form"
      hiCreateFormLayout(
        'layout
        ?items list(RadioField1 RadioField2)
    hiDisplayForm(MyForm)
  • swathiba24
    swathiba24 over 2 years ago in reply to Andrew Beckett
    Thanks for your feedback.
    Is there a possibility to disable only selected radiofields ?
    In the above example:
    When "Yes" is selected, we would like to disable "M1", "M3"
    When "No" is selected, we would like to disable "M2","M4","M5"
