  3. ICADVM18.1 undefined function techOrderLeLsw
  • Views 4627
TH20240912844
TH20240912844 over 2 years ago
ICADVM20.1 can use techOrderLeLsw() to change the LSW layer order, But ICADVM18.1 doesn't have this function. Is there any way to modify LSW layer order in IC18.1 to make it in my own order.
I can't modify .tf files
    If you are just trying to change the order in the palette, then the older techSetLeLswLayers should do what you want. The new function is specifically there to handle controlling the drawing priority in the context of incremental technology databases.
    If you need to control the priority too or are using iTDB you probably need to move to ICADVM20.1 or IC23.1
  • TH20240912844
    TH20240912844 over 1 year ago in reply to Andrew Beckett
    Dear Andrew,
    The problem has been solved, Thanks for your helps
    HT
