  3. hiCreateCyclicField : Value changes when the choices are...
  • Subscribers 150
  • Views 5982
hiCreateCyclicField : Value changes when the choices are updated
kkdesbois
kkdesbois over 2 years ago
When I update the list of choices of a cyclic, the selected value is updated to the first value of the nex choices list, even if the selected value is still part of the new choices list.
Is there a way to avoid that?
Code example :
trCyclicList = '("1" "2" "3" "4" "5" "6" "7" "8" "9" "10")
trCyclicField = hiCreateCyclicField(?name 'trCyclicField ?prompt "Cycle Through: " ?choices trCyclicList ?value "3" ?defValue "7" ?callback "println" )
hiCreateAppForm( ?name 'trSampleForm2 ?formTitle "Sample Form" ?callback "println( 'FormAction )" ?fields list(trCyclicField) ?unmapAfterCB t )
hiDisplayForm(trSampleForm2)
If I modify the choices list from the CIW :
trSampleForm2->trCyclicField->choices='("1" "2" "3" "4" "5" "6" "7")
Laurent
    Laurent,
    I can't find any requests or default mean to change this behaviour, but if you do:
    let(((curVal trSampleForm2->trCyclicField->value)) trSampleForm2->trCyclicField->choices='("1" "2" "3" "4" "5" "6" "7") trSampleForm2->trCyclicField->value=curVal)
    then it will preserve the current value. You could always make it a bit safer (to avoid a warning if the current value didn't exist):
      when(member(curVal trSampleForm2->trCyclicField->choices)
    Of course, you could wrap this up in a convenient function to change an selectively preserve current values on choice changes.
  • kkdesbois
    kkdesbois over 2 years ago in reply to Andrew Beckett
    Thanks Andrew.
    So It's the normal behavior.
    I will hence pass in a memorization step before updating the choices list as you suggest.
    Laurent.
    Andrew Beckett over 2 years ago in reply to kkdesbois
    Laurent,
    I wasn't sure on the expected behaviour, so I checked in IC5.1.41 too (in a release from 13 years ago) and the behaviour was the same there.
