  3. Tracing a net connection from M1 to the top most metal in...
  • Replies 7
  • Subscribers 152
  • Views 7853
Tracing a net connection from M1 to the top most metal in layout using SKILL script
MSP032
MSP032 over 2 years ago
I am trying to trace the connectivity of a net in layout using SKILL from M1 metal to the highest metal to which it is connected, and identify the net name of the highest metal through its label name.
I am using the "leMarkNet" function to highlight the net in layout, by writing,
"leMarkNet(list(84.243 133.027) ?startLevel 0 ?stopLevel 32 ?thickLine t)",
where the point is the origin of the M1 layer to be traced.
But, this is highlighting only the M1 layer, and is not tracing the connection to the higher layers.
Please let me know if I am missing something.
Mallikarjun.
  • skillUser
    skillUser over 2 years ago
    Hi Mallikarjun,
    most likely your 'markNetOptions' is not set up to include either the vias or both the vias and the other metals. You can adjust this graphically in a Layout window by starting the Mark Net command and then modifying the command options (typically the F3 bindkey) - look at the Via Layers and Connected Layers tabs. You may also need to modify the Stop Layers in case the probing goes too far. You can save your settings to a markNetOptions file and this can be the default when you next start the Mark Net tool - look at the documentation for more detail on this.
    Hopefully this helps you.
    Best regards,
    Lawrence.
  • MSP032
    MSP032 over 2 years ago in reply to skillUser
    Hi Lawrence,
    Thanks for your reply.
    The mark net options are already enabled in the GUI as shown in the snap below. But, the 'leMarkNet' is not highlighting above M1 layer.
    Please let me know if there are any other options that I need to set.
    Mallikarjun.
  • MSP032
    MSP032 over 2 years ago in reply to MSP032
    The connectivity is working fine, when I give some other point on the M1 metal.
    But it is highlighting the entire layout due to some shorts during highlighting as there are some MIM caps in the layout.
    My requirement is to trace the connectivity of the M1 metal to the topmost metal in layout it is connected to, while avoiding the shorts during highlight due to the MIM caps, and identify the net name of that top metal using labels.
    Please let me know what method would be best for this.
    Mallikarjun.
  • KSSB
    KSSB over 2 years ago in reply to MSP032
    Hi Mallikarjun,
    You can use the Net Tracer option, and the equivalent SKILL API to click on a point and get the netName. This would require proper Layout XL binding, and you need to setup the Net Tracer options similar to the Mark Net Options (You can save markNet options to a file, and then load the same in the netTracer custom options).
    Baig
  • MSP032
    MSP032 over 2 years ago in reply to KSSB
    Sure. I know to use the Net Tracer from Connectivity->Net Tracer. Please let me know the corresponding SKILL functions for the same.
    Thanks.
  • skillUser
    skillUser over 2 years ago in reply to MSP032
    lntAddTrace() would appear to be the function to add a new trace - there are many other "lnt" prefix functions which you might need to use in conjunction with this function. Also note that lntAddTrace is not a drop-in replacement for leMarkNet
    Best regards,
    Lawrence.
  • MSP032
    Thanks for providing the SKILL API for it. Started using it.
    I noticed one thing.
    When I highlight a net using "lntAddTrace" in a SKILL script by providing a net name, it doesn't highlight all of it.
    I mean, there will be many shapes belonging to that net name, which aren't yet highlighted by it.
    But, when I just open and hide the net tracer options GUI(Connectivity->net tracer->add/remove->F3) in layout window, and run my above SKILL script, it now highlights all the shapes belonging to that net.
    Please let me know what I might be missing.
    Mallikarjun.
