  3. Fixing path object off-grid
  • Views 4599
TzuYun Chang
TzuYun Chang over 2 years ago
I have used SKILL to create a path object for an octagonal inductor; however, there are off-grid problems at the corners. I am wondering if there is an existing code to create polygons at the corner and snap them to grid.
  • TzuYun Chang
    Hi, I am trying to write a script to generate an octagonal inductor using a path object; however, I encounter an off-grid error at all the corners leaving me quite frustrated. I found this post: https://comp.cad.cadence.narkive.com/vIgjhc56/create-path-in-45-degree-off-grid-in-the-corner-points-vle suggesting that there is a SKILL code for this corner problem already, but somehow I couldn't find it. If someone can point me in the right direction will be great. Thank you.
