  3. Issue while using dbLayerAndNot()
  • Subscribers 152
  • Views 5253
Nisanth SS
Nisanth SS over 2 years ago
I am working on a script to place  routing blockage layers over an IP using the prBoundary.
To derive the XOR data between the respective pins and the PR boundary, I’m using the dbLayerAndNot() function. However, the function consistently returns nil for any input combination.
Below is the test case I’m working with:
cv = geGetEditCellView()
bBox1=list(list(1.18 0.0) list(1.33 0.15)) ; eg. M2 pin
bBox2=list(list(1.75 -0.1) list(2.10 0.25)) ; eg. prBoundary
bBox_blockage = dbLayerAndNot(cv "ME3" bBox1 bBox2)
If you have any insights into why this might be happening or how to resolve the issue, your help would be greatly appreciated.
Thank you!
Nisanth.SS
    Nishanth,
    Please read the documentation for this function - you'll see that it expects the 3rd and 4th arguments to be lists of database objects for shapes, not bounding boxes.
    You can use dbPointArrayAndNot if you don't have any actual shapes - but in this case the arguments are lists of lists of coordinates representing the outlines of polygons (so not bounding boxes either). The result is a list of lists of coordinates of the resulting shapes (so you could create polygons from them).
  • Nisanth SS
    Nisanth SS over 2 years ago in reply to Andrew Beckett
    Thanks a lot Andrew, I used objects for 3,4 the arguments and It worked.
