  3. Multi Dimensional Generated Plot During Monte Carlo Analysis...
  • Views 6291
Multi Dimensional Generated Plot During Monte Carlo Analysis with Parametric Sweep
mnmz
mnmz over 2 years ago
I am calculating a current at specific node, meanwhile I am running parametric analysis by sweeping the digital code. I can plot the current after the sweeping and do some post processing in the calculator. I want to do the same thing with Monte Carlo analysis, now I can plot the current but the x-axis is technically the monte carlo seed number, so I need to change the x-axis to the "code Number" so that I can the correct plot, now I do the same process in the calculator but it gives an error and fail to generate the result using the same expression.
I tried doing easy expression like Value function to get the data from the plot after changing the axis, but it fails. is there any was I can do this? or there is something wrong in my setup?
These are mu Cadence versions (I have already tried different versions of MMSIM and Virtuoso and did not see the issue is fixed):
MMSIM_201_ISR13
Virtuoso_20.1_ISR34
    Seeing a plot would help, but I am guessing you should use the swapSweep function to change the x-axis to your digital code variable.
  • mnmz
    mnmz over 2 years ago in reply to Andrew Beckett
    Hi Andrew, You are right, I am using the swapsweep function to change the x-axis, but the issue is right after that. I want to use the new plot (axis updates) in the calculator to measure some values, but the calculator gives error for that expression while I am running Monte Carlo, but for a single Run it works fine.
    Andrew Beckett over 2 years ago in reply to mnmz
    It would rather help to know:
    1. The expression which is failing
    2. The error message
    3. What you are sweeping
    Otherwise there's a lot of guesswork to try to give a solution...
  • mnmz
    Thank you Andrew for your reply.
    This is the expression:
    value(leafValue( getData("/Diff_Current" ?result "tran" ?resultsDir "/AAA/BBB/...") "mcparamset" 26) 5 )
    Error message in icfb:
    ERROR (VIVA-3302): expression evaluation failed: value(leafValue( getData("/Diff_Current" ?result "tran" ?resultsDir "/AAA/BBB/...") "mcparamset" 26) 5 )
    I am sweeping parameter in the verilogA block (I give a number from 0 to 127 it generates the binary code), so I am sweeping the Code_Number and measure current, while running over Monte Carlo simulation. I have the measured current data and then plot them, it automatically generates "current vs mcparamset", then I right click on the x-axis and using Swap Sweep VAR to change the x-axis to Code_Number. Now I have the plot of Current vs Code Number for each Monte Carlo Run. Then I go to the calculator and by clicking on the waveform, bring the expression to the calculator to generate the above expression.
