  3. Create Rectangle Blockage layers : Command used dbCreateAreaBlockage...
  • Views 4744
Create Rectangle Blockage layers : Command used dbCreateAreaBlockage , dbCreateLayerBlockage
Nisanth SS
Nisanth SS over 2 years ago
I am working on a script to place and route blockage layers over an IP.
I need to place both instance blockage and routing blockage layers in a rectangular shape.
However, functions like dbCreateAreaBlockage and dbCreateLayerBlockage only allow specifying polygon points.
Could you please guide me on how to place instance and routing blockage layers in a rectangular shape effectively?
TestCase:
Thank you!
Nisanth.SS
    Nisanth,
    I'd have thought that was pretty obvious - you need to construct a list of four points, which you could get using combinations of xCoord(lowerLeft(bBox)), yCoord, upperRight etc. Or you could use:
    bBox='((0 0) (5 5))
    destructuringBind(((llx lly) (urx ury)) bBox
      dbCreateAreaBlockage(cv list(llx:lly llx:ury urx:ury urx:lly))
    which is quite a compact way of writing it.
