  3. Maestro : Config sweep in nested configuration
  • Views 5380
Shankar PA
Shankar PA over 2 years ago
I am having a testbench hierarchy as shown below.
I wanted to do a config sweep(using maestro's config sweep functionality) on the instances I0_1, I0_2
Currently this works well if the instance I0 is bound to schematic view in config1.
However, when the instance I0 is bound to config2[A nested config and the hierarchies inside I0 doesn't change], the netlist seems to be generated based on the bindings in config2 and the config sweep settings in maestro are not honored.
How do I accomplish config sweep's of an instance when there is nested sweep configuration.
Shankar
  • Alonso Schmidt
    Alonso Schmidt over 2 years ago
    Hi Shankar,
    Unfortunately this is not supported. You can only sweep what is present at the top-level config, but not what is in a level below as everything defined under config2 in your case.
    Best regards,
    Alonso
