  3. Issues with Calculator
  • Views 4878
spatz
spatz over 2 years ago
I have issues with the schematic selection toolbar.
For example, I performed an AC analysis, pressed "vf" in the schematic toolbar and then clicked on a net in the schematic; I get the following error message:
*Error* eval: undefined function - caliCalcAlgebraicInput
IC6.1.8-64b.500.27
    This was something that was briefly broken - and fixed in IC6.1.8-64b.500.29 . If you really can't move to a newer sub-version, then please contact customer support (submit a support case after logging in); there's a patch to fix this in the older affected versions (please reference CCR 2702333).
  • spatz
    spatz over 2 years ago in reply to Andrew Beckett
    Thank you!
