  3. How to obtain the PSF directory for each sweep point using...
  • Subscribers 152
  • Views 6115
How to obtain the PSF directory for each sweep point using Skill or Ocean?
dontpanic
dontpanic over 1 year ago
Hi! I normally run matlab post-processing scripts on my testbenches, and would take advantage of the "axlCurrentResultsPath" function to get the PSF directory of each individual point in sweeps (my testbenches usually dump the simulation data of interest in that directory). In fact, I often would use the following 1-line script to define an output "pointPsfDir" in my Maestro views, which is then used by other outputs for doing further processing:
% pointPsfDir.m
axlResult = axlCurrentResultsPath();
How can I achieve the same *without resorting to Matlab* (I need to cut down Matlab usage as much as possible)?
I tried using the Ocean script below (I initially wanted to do this with a Skill function but was unable to achieve what ocnxlGetPointId() does) to the exact same purpose (i.e. define an output in my Maestro views with the PSF directory of each individual sweep point), but despite it working for 1-point simulations (i.e. the "Nominal" corner), it doesn't work when running sweeps (which I normally define as corners in my Maestro views):
; simInfo.ocn
    session = axlGetWindowSession()
    sessionDB = axlGetMainSetupDB(session)
    testName = nth(0 setof(testName cadr(axlGetTests(sessionDB)) axlGetEnabled(axlGetTest(sessionDB testName)) ))
    historyID = axlGetHistoryEntry(sessionDB axlGetHistoryName(axlGetCurrentHistory(session)))
    cornerName = axlGetCornerNameForCurrentPointInRun()
    designPointId = ocnxlGetPointId()
    pointPsfDir = axlGetPointPsfDir(historyID testName ?cornerName cornerName ?designPointId designPointId)
    axlOutputResult(pointPsfDir "pointPsfDir")
    axlAddOutputs('("pointPsfDir"))
For example, I get these errors in the CIW when running a 3-point sweep defined as a corner named "TB__VDD":
ERROR (ASSEMBLER-2224): Could not find point id for corner name : TB__VDD_0 and design point : nil pair
Ensure that the corner name and design point are correct and then retry.
ERROR (ASSEMBLER-2709): Evaluation of output 'pointPsfDir' returned 'nil' for test:'debug'.
Ensure that the definition of output is correct.
ERROR (ASSEMBLER-2224): Could not find point id for corner name : TB__VDD_1 and design point : nil pair
ERROR (ASSEMBLER-2224): Could not find point id for corner name : TB__VDD_2 and design point : nil pair
Thanks in advance for any help!
KR, Jorge.
  • dontpanic
    Well, after lots of debugging it seems I got an Ocean script that kind of works (see below). For some reason, when running sweeps the outputs that depend on the value of "pointPsfDir" never get properly evaluated upon running the simulation, requiring always output re-evaluation with the "full" option.
    I would still be grateful for any feedback on (1) code improvements, or (2) a way of doing it with a Skill function (so as not to need to define Ocean outputs in Maestro).
    KR, Jorge.
    P.S. Also there seems to be some sort of "caching" of the script, because changes in it don't seem to immediately reflect in the executed behavior (e.g. after commenting the debug printf()'s, the text is still printed to the CIW) ...if this is the case, is there a way do disable caching it altogether?
    ; simInfo.ocn
        if( cornerName==nil then
    ;        printf("D: Single-point sim detected =========================================\n")
        else
    ;        printf("D: Sweep detected =========================================\n")
            printf("cornerName: %s\n" cornerName)
            rexCompile(".*_")
            designPointIdStr = rexReplace(cornerName "" 0)
            printf("designPointIdStr: %s\n" designPointIdStr)
            rexCompile(sprintf(nil "_%s" designPointIdStr))
            cornerNameRoot = rexReplace(cornerName "" 0)
            printf("cornerNameRoot: %s\n" cornerNameRoot)
    ;        pointPsfDir = axlGetPointPsfDir(historyID testName ?cornerName cornerName ?designPointId designPointId); ; doesn't work :(
            pointPsfDir = axlGetPointPsfDir(historyID testName ?cornerName cornerName ?designPointId 1)
        ; Actual outputs
  • dontpanic
    dontpanic over 1 year ago in reply to dontpanic
    Nevermind--the above script will break as soon as more than 1 test is enabled. As it seems there's no way to determine the test being run using Skill/Ocean, I guess I'm stuck with using a Matlab for the time being...
  • henker
    henker over 1 year ago in reply to dontpanic
    I'm using the following to do some "per simulation" post processing (stripped out from actual code, so handle with care)
    ;; Maestro (assembler/explorer) pointSimulationCompleted trigger
    ;; is triggered multiple times
    procedure( Mae_pointSimulationCompleted(session history testName dataPoint)
    ;printf("pointSimulationCompleted %L %L %L %L\n" session history testName dataPoint)
    	let( (psfDir)
    		; axlGetHistoryResultsDir(history) get the overall result dir
    		; netlist and psf are in <ResultsDir>/<dataPoint>/<testName>/
    		psfDir = sprintf(nil "%s/%d/%s/psf" axlGetHistoryResultsDir(history) dataPoint testName)
    		printf("PSF location for the current run is %s\n" psfDir)
    		t
    ;; Maestro (assembler/explorer) trigger initialisation
    procedure( Mae_InitTrigger(session_name)
    	; register pointSimulationCompleted callback
    	; (executed after single simulation point is finished)
    	axlSessionConnect(session_name "pointSimulationCompleted" 'Mae_pointSimulationCompleted )
    ); procedure
    ; Explorer/Assembler Trigger
    ; Register a callback to connect the triggers on session start
    axlSessionRegisterCreationCallback('Mae_InitTrigger)
    The caching is done with starting explorer/assembler, the session gets all data on startup prob. to be able to run standalone and not being disturbed while running the simulation. So if you change something on the code, you have to restart the simulator session.
