  3. How to run code in function of OK & Cancel buttons
  • Subscribers 150
  • Views 2889
kkdesbois
kkdesbois over 1 year ago
In my script, I open a form which creates files when OK button is clicked.
I'd like my script to go on in a direction (do things with the created files) when the OK button of the form is pressed and in another direction when the Cancel button is pressed.
I have no control on the OK/cancel button callbacks of the form.
I'm searching a way to make my script wait for an action on OK/Cancel of the form and go on according to which button has been clicked.
Note that the form opened has not a modal dialogStyle.
Laurent.
    Laurent,
    When creating your form (with hiCreateAppForm or hiCreateLayoutForm), you can specify the ?callback argument as a list of two callbacks - the first is for OK and the second for Cancel.
    See Cadence User Interface SKILL Reference -- hiCreateAppForm - hiCreateAppForm
  • kkdesbois
    kkdesbois over 1 year ago in reply to Andrew Beckett
    Thanks Andrew,
    Unfortunately I don't own the code creating the form, I only call the function creating the form. So, I can't modifiy the callback
    Andrew Beckett over 1 year ago in reply to kkdesbois
    You can change the callback:
    hiChangeFormCallback(myForm list('CCFokCallback 'CCFcancelCallback))
  • kkdesbois
    thanks
