  3. generate bus from symbol but compact style
  • Views 4348
IW202412053139
IW202412053139 over 1 year ago
I have a symbol with pin name say ABC<3:0,5,6>
When I hit spacebar to generate the nets from the symbol, the net generated is ABC<3:0>,ABC<5>,ABC<6>. Anyway to make it same as the pin name in a more readable form? thanks.
    I took a quick look and can't see any controls to stop it expanding individual bus elements into bundles as you've shown, nor did I find any reports of this.
    I suggest you contact customer support (submit a support case after looking in from the Cases menu) so that this can be enhanced. I guess split bus pins are not that common (at least in this usage) which may be why this hasn't been reported before.
