  3. Is there a reverse function of axlSessionRegisterCreationCallback...
  • Views 5720
Is there a reverse function of axlSessionRegisterCreationCallback, i.e. axlSessionUnRegisterCreationCallback ?
TKTAN1973
TKTAN1973 over 1 year ago
Dear Experts,
Assuming I had these loaded during virtuoso startup in a .cdsinit file.
procedure( func1(session @rest args)
let(()
printf("Length of arguments: %d\n" length(args))
); let
); procedure
(axlSessionRegisterCreationCallback (lambda (session) (axlSessionConnect session "postInstall" 'func1)))
(axlSessionRegisterCreationCallback (lambda (session) (axlSessionConnect session "postCreatedTest" 'func1)))
(axlSessionRegisterCreationCallback (lambda (session) (axlSessionConnect session "preRun" 'func1)))
So after opening a maestro view, I can see what I expect in the CIW, e.g. Length of arguments: 0 or Length of arguments: 3 when I made a copy of the test, etc.
Thus comes my question, is there a axlSessionUnRegisterCreationCallback option that can unregister what I register? I know there is a axlSessionDisconnect function but it does not appear to remove what I had register for the following signals: postInstall, postCreatedTest and preRun after closing and reopening the maestro.
I'm trying to code an utility that allows us enable/disable some func to be trigger during "postInstall", "postCreatedTest" and "preRun". Enabling is easy but I'm scratching my head whether there's any easy way to disable it without commenting the lines away and restart virtuoso session.
Thanks in advance for any help/suggestion that you could offer.
Ps: I've search the forum and mostly the searches returns how to register the callback creation which I've been able to do so and not how to unregister it. But I might have miss out something due to my limited search so pardon me if this has been asked before.
    There's no function to unregister the session creation callback.
    Of course, what you can do is have the function registered with axlSessionRegisterCreationCallback conditionally call axlSessionConnect to only register the signal callbacks you want to be triggered in the newly created session. Or you could have the triggers always connected and then conditionally do something within them or not.
  • TKTAN1973
    TKTAN1973 over 1 year ago in reply to Andrew Beckett
    Thanks Andrew for such an obvious answer~ What was I thinking in the first place? The solution is so straight forward. Thank you so much!
    Is there any shortcomings that you could think off using either approaches?
    The most obvious benefit I see in the second approach is that when the session is already created, it can take effect immediately if you change the condition. Where as the first approach can only take effect after a new session is started when the condition change.
    ;register a callback to connect the triggers on ADE XL session start
    (axlSessionRegisterCreationCallback 'ADEXLTriggers_func1)
    (axlSessionRegisterCreationCallback 'ADEXLTriggers_func2)
    ;connect ADE XL triggers
    (defun ADEXLTriggers_func1 (session)
    if(boundp('myVar) && myVar!=nil then
    else
    (axlSessionDisconnect session 'func1)
    (defun ADEXLTriggers_func2 (session)
    (axlSessionConnect session "postInstall" 'func2)
    (axlSessionConnect session "postCreatedTest" 'func2)
    (axlSessionConnect session "preRun" 'func2)
    ;define a handler to connect to a trigger
    let(()
    printf("Func1: Length of arguments: %d\n" length(args))
    ); let
    ); procedure
    procedure( func2(session @rest args)
    let(()
    printf("Func2: Length of arguments: %d\n" length(args))
    ); if
    ); let
    Andrew Beckett over 1 year ago in reply to TKTAN1973
    In terms of efficiency it's unlikely to make any noticeable difference - I'd probably default to the first approach unless I needed the ability to change the behaviour during the session (as you said).
    Note that in ADEXLTriggers_func1 you don't need the axlSessionDisconnect call - the functions won't be connected to the signal unless you connected them in the first place for that session, which won't have happened since you're in the session creating callback.
  • TKTAN1973
    Apologies for the late response as I was OOO. Thanks Andrew for the advice. You are correct. ADEXLTriggers_func1  is only register during session setup. So there's no need for the 'else' condition to disconnect. You have fully answer my query. Pray
