  3. Regarding fast edit using SKILL & How to Set Level using...
  • Views 2319
Regarding fast edit using SKILL & How to Set Level using cellview Id in SKILL
skillEater
skillEater over 1 year ago
I am trying to Add vias using viaGenerateViasAtPoint but I am getting some issues like not adding via where there is a stack via.
Which I am thinking due to setting Edit level.(If not please correct me).
We set this using Shift+F and Ctrl+F in layout window. Can we set this using cellview databasein SKILL.
And Is there any way to Fast Edit Vias using SKILL like we do in Via form while editing Layout.
Any help will be Welcome.
Thank you.
Ganesh Doddipatla.
    Ganesh,
    I don't think that viaGenerateViasAtPoint() would be dependent upon the displayed stop level - you can do that though with:
    hiGetCurrentWindow()->stopLevel=31
    I wonder whether instead you just need to use dbOpenHier(cvId 31) to fully open the design hierarchy?
  • skillEater
    skillEater over 1 year ago in reply to Andrew Beckett
    Thank you for the help. I tried it but it's not helping as you said in the previous response.
    According to my observation why it is not adding vias at a certain location is because the metals are in one cell view and the vias are present in another cellview. In some cases there is a bottom metal via in one level and top metal via in another level.
    So that is the reason why I thought if you set stop level to 20 it should add a via It should be able to add via. But it has not worked.
    I tried adding a rectangle where there is vias instead of just adding vias.
    But I am getting some issues like not getting enough vias according to area available because of the vias previously added and reduced due to some DRC.
    And also, if there is way to Fast edit vias using database id through skill that will be helpful.
    Thank you
    Ganesh Doddipatla.
    Andrew Beckett over 1 year ago in reply to skillEater
    Ganesh,
    Since the "Fast Edit" feature is an interactive capability of the create via command, I don't really understand what you mean by asking for this through SKILL. For your specific issue, please give an example of what the layout looks like and the code you are trying to use - it's very hard to diagnose problems that you can't see and only have a rather loose description of your observations.
