  3. I cannot use basic functions of skill in virtuoso (ex. nindex...
  • Views 4731
I cannot use basic functions of skill in virtuoso (ex. nindex)
YS202501078642
YS202501078642 over 1 year ago
fstInst=car(MchInstList)
numMchInst=length(MchInstList)
remdMchInstList=remove(fstInst MchInstList)
(setq name2 (fstInst~>name))
(setq index2 (nindex( name2 "<")))
(setq nameBeforeLessThan (substring name2 0 index2))
fstInst~>name=strcat(nameBeforeLessThan "<" artMakeString(numMchInst-1) ":" "0" ">" )
I want to find position of "<" in variable name2
so i search the skill code documentation and I found "nindex" function
but when i tried to use "nindex" function,
*Error* eval: not a function - nindex(name2 "<")
this error has become.
is there any file to load before using such functions?
Now I use 6.1.8-64b version virtuoso
  • ebecheto
    ebecheto over 1 year ago
    Hi YS,
    (setq index2 nindex( name "<"))
    You have extra parenthesis around. That is your mistake.
    I am not sure what you want to do, but see below and example to reverse bits in a bus or translate it in a bracket like syntaxe.
    name="bus<1:0>"
    ; nindex(name "<");=> 4
    splitName=parseString(name "<:>");=> ("bus" "1" "0")
    dbGetNameNumBit(name);=> 2
    ; check splitName length mayby
    strcat(nth(0 splitName) "<" nth(2 splitName) ":" nth(1 splitName) ">");=> "bus<0:1>"
    strcat(nth(0 splitName) "[" nth(2 splitName) ":" nth(1 splitName) "]");=> "bus[0:1]"
    ___ Hope it helps __
    ++Ed
  • YS202501078642
    YS202501078642 over 1 year ago in reply to ebecheto
    Actually I would like to do combine multiple instance which has same name
    For example, there are instances which name is "I0<0>", "I0<1>", "I0<2>", "I0<3>"... "I0<12>"
    So, I want to combin them as "I0<12:0>".
    That's why I need position of "<".
    Of course, there is some way to do something like that. But, there is some error
    SKILL: How to combine multiple instances of same master connected to the same net name in a design into an iterated instance
    I want to combine all of the instance which has same name before bracket.
    Also, if I can, I want to make that skill code that can do on same name instance and same net (ex, in<0>, in<1> ...) either.
    Thanks.
    Andrew Beckett over 1 year ago in reply to YS202501078642
    You could use the code in this post: Generating Schematic pin list to collapse a list of names into a vector.
