  3. CDF ?storeDefault doesn't work after changing instance ...
  • Views 2227
CDF ?storeDefault doesn't work after changing instance master
RVERP
RVERP over 1 year ago
I have a procedure where I replace an instantiated pcell with another pcell. This I do by changing the instance master (instance~>master = newMaster). The new master has the same cdf parameters, and adds additional ones.
I have noticed that for the instances I have changed this way, ?storeDefault doesn't work.
Now I make a mixed layout with updated instances (changed with my command) and intances of newMaster created with create instance. When I update the cdf default, the ones changed with my command take the new default, while the instantiated ones don't.
I hope this is a bit clear. It seems the cdf defaults are only stored when you create an instance. Replacing it doesn't store the default since there never was the instantiate step. Are there other ways to change the master of an instance? So I can test what this does with ?storeDefault.
    Changing the master will not affect any of the user-defined properties on the instance. That means that whatever properties that were stored locally on the instance will remain (so anything that was placed in the editor with a CDF default value and storeDefault on will have the local property stored on the original device). The new device's CDF has no impact on the remastering.
    Is this layout or schematic? I think (I haven't checked) leRemasterInstances might handle this, but I'm not sure (and that remasters all instances of a given master, so may not be what you want).
    I think I might need a better understanding of how the CDF is different before and after - perhaps this is better handled via customer support?
  • RVERP
    RVERP over 1 year ago in reply to Andrew Beckett
    This is layout.
    The CDF of the newMaster has the same parameters as the old instance, but includes additional ones. These are not stored yet on the instance as a parameter since there was never a command to instantiate. Maybe here dbCreateParamInstByMasterName is used. I the help it says specifically this command stores the cdf parmeters as a property on the instance.
  • RVERP
    leRemasterInstances doesn't seem to work.
  • RVERP
    I tried a different method. I replace the instance with a new one using the new master and using the prop of the original instance.
    First this didn't work and gave the same result (not storing the default), but if I instantiate a new instance (dbCreateParamInstByMasterName), run cdfUpdateInstParam to store the defaults and the update the parameters to match the old instance (dbReplacePropList), the defaults are stored and all is as expected.
