  3. The code statements that not in procedure can not be saved...
  • Views 5549
The code statements that not in procedure can not be saved to context file when build context file
Yush
Yush over 1 year ago
The code statements that not in procedure can not be saved to context file when build context file using the following codes:
procedure(makeContext(cxt cxtPath sourceCodePath)
let(((newPath strcat(sourceCodePath "/" cxt))
(oldPath getSkillPath())
(fileName strcat(cxtPath "/" cxt ".cxt"))
(oldStatus status(writeProtect))
);end local var
printf("Building context for %s\n" cxt)
setSkillPath(newPath)
sstatus(writeProtect t)
setContext(cxt)
loadi(strcat(sourceCodePath "/" cxt "/" cxt ".il"))
saveContext(fileName)
callInitProc(cxt)
setSkillPath(oldPath)
unless(sstatus(writeProtect nil)
nil
);end unless
t);end let
);end proc
procedure(buildContext(cxt cxtPath sourceCodePath)
progn(
deleteFile(strcat(cxtPath "/" cxt ".cxt"))
cond(
(isDir(cxt sourceCodePath)
(t
printf("Can't find context directory %s\n" cxt)
);end cond
);end progn
);end proc
;;code
    Can you give an example? Your question is not very clear.
  • Yush
    Yush over 1 year ago in reply to Andrew Beckett
    such as: insert pulldown menu to layout window
    procedure(skAddMenu(arg)
    let(()
    ;;the following codes are not working after loading context file
    ;;guess the code statements are not saved to context file when builded
    foreach(view list("maskLayout" "maskLayoutXL")
    deRegUserTriggers(view nil nil 'skAddMenu)
    another case is hiSetBindkey()
  • Yush
    hi Andrew, is my reply description not clear enough?
    Yush
    Andrew Beckett over 1 year ago in reply to Yush
    Yush,
    It's clear. I just haven't had a chance to do the relevant experiments and give you a solution (I've had the day job taking up my time).
    I hope to get to this soon.
    Andrew Beckett over 1 year ago in reply to Andrew Beckett
    Yush,
    This is expected and is documented behaviour.
    You have two choices here:
    1. Put the relevant code (the foreach loop calling deRegUserTriggers) inside a function definition, and then call defInitProc to define the function to be called when the context is loaded. You then need to use callInitProc(contextName) after the loadContext().
    2. Use loadTopContextForms() to load the code when you are building the context. This produces a different kind of context file which is (in essence) similar to loading the code and so can contain top-level calls such as you have them.
  • Yush
    Andrew,
    Thanks for reply.
    I had tried the first choice before, the codes still not working(maybe i forgot). I' ll try again and try the second method.
    Yush
