  3. Skill code to create schematic view(with only pins) from...
  • Views 1149
Skill code to create schematic view(with only pins) from the input file containing PIN and direction
Nisanth SS
Nisanth SS over 1 year ago
I need to create a schematic and symbol view for the pnr block which has only gds and netlist.
From netlist I've create a pinlist file with <pin name> <direction>.
Could you please  help me to create a skill script to create the schematic and symbol views?
Nisanth SS
    You can use schPinListToSymbol and schPinListToSchem. If you want an example of the format of the pin list, you could use schSymbolToPinList to see that.
    Or you could use File->Import->SPICE to produce schematics and symbols from the netlist.
