  3. Skill code to assign Connectivity information to path in...
  • Views 5629
Skill code to assign Connectivity information to path in virtuoso layout editor
Nisanth SS
Nisanth SS over 1 year ago
I'm writing a script to take the value of Property and assign it as connectivity to the same net.
I was able to print both the Property and Connectivity values for the net, but I'm not able to assign the variable to Connectivity
Paths = geGetSelSet()
path = car(Paths) ; select first path
path~>net~>name ; print current connectivity name
net_name=car(path~>prop~>value) ; print the property name to variable
path~>net~>name = net_name ; assigning net name
*Error* setSGq: (DB-370034): dbSetq: Cannot set attribute - name
How to set the attribute to  path~>net~>name ?
Nisanth.SS
  • mbracht
    mbracht over 1 year ago
    Hi Nisanth,
    Even thouhg I am not Andrew ;-) I think I can answer this question. The name of a net OA object is a read only attribute, you cannot reassign it. You can use the dbRenameNet(..) function though:
    (dbRenameNet path~>net net_name)
    Max
  • Nisanth SS
    Nisanth SS over 1 year ago in reply to mbracht
    Thanks Mbracht
    I used the dbRenameNet(..) function and was able to attach the connectivity, but I'm facing the following challenges,
    The function throws an error message if the connectivity information is not present in the path.
    It writes random values to the net.
    Even though I'm not changing the value of net_name, it prints "TRUE" along with the original net_name.
  • mbracht
    mbracht over 1 year ago in reply to Nisanth SS
    Hi Nisanth,
    Well if - like you say - there's no connectivity then there's no net OA object on the path in the first place and in such dbRenameNet() which expects the net as it's first arguments throws an error. That is an expected behavior. Can you please elaborate on what exactly you want to do. The other thing is that the statement net_name=car(path~>prop~>value) works only if there's only one property on the path, path~>prop~>value returns a list of the values of all user defined properties. It'd be much safer to access to access the property value in terms of it's name. Assuming the name of the user defined property would be myNet (and I take it you have the name of that property) you have to:
    net_name=getq(path myNet)
    But again, we need a little more context about what you actually want to do and why you want to do it to give a reasonable answer.
    Max
