  3. automatic Router using to route shortest path between two...
  • Replies 11
  • Subscribers 152
  • Views 8183
automatic Router using to route shortest path between two pin (IN virtuoso studio IC23.1) it is using in layout XL
KR20250126941
KR20250126941 over 1 year ago
Hi to all, hope you all are fine and doing well
   i am trying to use virtuoso auto route along with wire assistant to route between two pins, the problem is it is not following Metal orientations while routing and creating drc issues so plz help me to resolve this issuese
  • SR202501288723
    SR202501288723 over 1 year ago in reply to RobMan +1
    Sir we don't have licence for MXL right now So we are doing it in Layout XL using wire assistance Can you help us to suggest some more options and env variable for better routing and shortest routing…
  • RobMan
    RobMan over 1 year ago in reply to SR202501288723
    I'm not sure VSR will be up t observing all the more complex advanced node rules.
    What via configuration do you have? Please make sure its 'Preferred' or 'Automatic'...
