  3. Virtuoso deleting points when setting new path points (Bug...
  • Views 4163
Virtuoso deleting points when setting new path points (Bug)
Betoo
Betoo over 1 year ago
Hi everyone,
In one of my scripts I have a path, path = car(geGetSelSet())
width = 0.6um
points = ((-20000.0 132.5) (-21082.29 132.5) (-23107.27 136.35) (-23272.27 132.5) (-23279.18 132.5))
Now I calculate new points and set those new points using path~>points = newpts. The last point calculated happens to be the same as the second to last
newpts = '((-20001.87 132.5) (-21082.29 132.5) (-23107.27 136.35) (-23272.27 132.5) (-23272.27 132.5))
Now when I query the points of this path with path~>points, it returns:
((-21082.29 132.5)
(-23107.27 136.35)
(-23272.27 132.5)
It looks like virtuoso is incorrectly deleting the first point along with one of the duplicate points. My version number is: IC6.1.8-64b.500.26 . Is there any way around this besides deleting the original path and then creating a new path using dbCreatePath? This is the workaround I am currently doing when these points are not set correctly.
Beto
    Andrew Beckett over 1 year ago +1
    Beto, You're right - this does seem strange. I filed Change Request #3105980 to see what's going on. As a workaround, you can use this: path~>points=dbCompressPointArray(newpts nil cv~>DBUPerUU) …
    Beto,
  • Betoo
    Betoo over 1 year ago in reply to Andrew Beckett
    Thanks for this! This is working perfectly and is much more elegant than the way I was doing it.
    Cheers,
    Beto
