  3. how to merge a list of pins back into bus<0:7> data<8:15...
  • Views 1585
how to merge a list of pins back into bus<0:7> data<8:15>
ebecheto
ebecheto over 1 year ago
Hi all, does anyone knows if this function already exist :
I have a list of expanded nets. Let say, they are already removed from duplicates, and sorted alphanumerically
nets='("net<0>" "net<1>" "net<2>" "clk" "data<0>" "data<1>" "data<3>" "reset" "sig<9>" "sig<10>" "sig<11>" "sig<12>")
; Expected result :
netBusListMerge(nets)=='("net<0:2>" "clk" "data<0:1>" "data<3>" "reset" "sig<9:12>" )
It is a bit like the reverse function of dbProduceMemName() i want, but for a list of sorted random pins.
I assume i am not the first one who add this need.
Any help is welcomed.
Regards
  • henker
    henker over 1 year ago
    I remember vaguely to have seen something like this either in the forum or in support but was not able to find it again. Maybe somebody else has a better memory.
    However, I have an older piece of code that might almost fit your requirements, although prob. not very efficient. I've not used it in applications so it may not cover corner cases (was just a proof-of-concept). So, handle with care.
    One thing is that the bus order is not determined from the input sequence. Although it accepts the bits ascending/descending/mixed, the output is always MSB-first. If you need it the other way, change the "base binx ainx" arguments to "base ainx binx", or extend it to also remember the order of the bits (would go into the 'merge' part).
    ; unroll list of bus and bit names
    procedure(unroll_busNameList(nameList)
        let( (res tmp new n a b base ainx binx fnc)
            fnc = lambda( ()
                when( base
                    new = if(binx==ainx
                        sprintf(nil "%s<%L>"    base ainx)
                        sprintf(nil "%s<%L:%L>" base binx ainx)
                    res = tconc(res new)
                    base=nil
            foreach(name nameList
                tmp=parseString(name "<:>")
                n = car(tmp)
                if( cadr(tmp) then
                    ; name is bus or single bit
                    a = atoi(cadr(tmp))
                    b = if(caddr(tmp) atoi(caddr(tmp)) a)
                    cond(
                        ( !numberp(a) || !numberp(b)
                            error("invalid indices in %L\n" name)
                        ; merge
                        ( base==n && binx+1==a a=ainx)
                        ( base==n && ainx-1==b b=binx)
                        ; output cache
                        ( t funcall(fnc))
                    ); cond
                    base = n
                    ainx = a
                    binx = b
                else
                    ; name is scalar
                    ; output cache
                    funcall(fnc)
                    res = tconc(res n)
            ; output remaining cache
            funcall(fnc)
            car(res)
        ); let
    Andrew Beckett over 1 year ago in reply to henker
    Here's some code I've posted before which does this. This does preserve the order...
