  3. vmsUpdateCellViews disable automatic symbol creation
  • Views 3881
SimhanAnalog
SimhanAnalog over 1 year ago
vmsUpdateCellViews for a systemverilog view compiles the view and shows warnings/errors and also checks other views like symbol, schematic if the ports match. If symbol is not present it shows a popup asking for symbol view creation. In order to disable all these popups I set
vmsCrossViewCheck = nil
vmsRunningInUI = nil
So that it doesnt show popup if there are any cross view mismatches and if there are any parser warnings.
But when I run for a view that doesn't have symbol it silently creates symbol
vmsUpdateCellViews(?lib lib_name_d, ?cell module_name, ?view "systemVerilog", ?viewt "systemVerilogText")
 I was thinking if I disable popup and crossviewcheck it shouldn't create symbol if it doesn't exist. Is there some option to disable symbol creation?
    Use vmsUpdateSymbolAfterEdit = nil
    See: How can I perform a check and save of a functional view using a SKILL command without opening the functional view from GUI?
  • SimhanAnalog
    SimhanAnalog over 1 year ago in reply to Andrew Beckett
    Thanks Andrew. This helped.
    I guess you have been the only constant in this changing world for the past 15+ yrs(maybe more. I have interacted for this time).
