  3. Add button on Parameter tab PCELL
  • Views 4241
Esteban Saavedra
Esteban Saavedra over 1 year ago
Hi All,
I'm working with pcell SKILL coding, and I want to know, is it possibly to add an extra button in the parameter tab GUI at bottom next to OK, Cancel and Apply buttons?
Sorry, I tried to add a image for better explanation but the tool is not allowing me to do it, hope previous senetence is enough.
Thank you.
Cordially,
Albert Esteban Saavedra Hernandez
    I'm assuming you're taking about the Edit Properties form in the layout editor.
    This is not possible; you can control the parameters on that tab (typically via the CDF parameters for the cell), and you can have "button" CDF parameters, but this will not add buttons to the bottom of the form.
  • Esteban Saavedra
    Esteban Saavedra over 1 year ago in reply to Andrew Beckett
    Thank you, I already implemented a second button using hiDisplayAppDBox, but I have a doubt now, when create the text to display, everything is showed in a singe row, how can I make a change of line to avoid that?
          cdfCreateParam(
                cdfId
                ?name       "customInfo"
                ?prompt      "Custom Info"
                ?display      "cdfgData~>customMode~>value == \"ON\""
                ?type       "button"
                ?callback   "hiDisplayAppDBox(
                                        ?name 'CustomInfo
                                        ?dboxBanner  \"Custom Info\"
                                        ?buttonLayout 'Close
                                        ?dboxText   \"To be able to use the custom section for PADs, please follow the next guidelines:
    1. The list names for Custom Pads, Pin Names and Custom Noise Levels should be the same, if not a text will show 'List lenghts for PADs, Pin Names and noise type should be equal' 2. The preferred nomenclature for Noise Levels is as follows: a. MN  - Medium Noise b. MLN - Medium Low Noise c. LN  - Low Noise d. ULN - Ultra Low Noise if any othe nomeclature is used, the text will be replaced for 'invalid Noise Level'\" 
          );cdfCreateParam
    Cordially,
    Andrew Beckett over 1 year ago in reply to Esteban Saavedra
    Within the string passed to ?dboxText, add \n (backslash n) anywhere you want a newline (line break) to spread the text over multiple lines.
