  3. Replace instances in a schematic by other instances
  • Views 5485
StephanWeber
StephanWeber over 1 year ago
I have a schematic open in Schematic entry, and want e.g. to replace all instances of nmos_3/symbol of tsmc18rf lib to nmos/symbol of bhvLib. No need for property mappings here.
Is there a simple skill code for this?
Alternatively, I can specify the schematic to be used via lib/cell/view. Then having a target schematic as output would be best.
Bye Stephan
    Do you need SKILL? Use Edit->Replace and search for "master" and search for "tsmc18rf nmos_3 symbol" and replace with the new master "bhvLib nmos symbol".
  • skillUser
    skillUser over 1 year ago
    Hi Stephan,
    something like this perhaps?
    foreach(ih geGetEditCellView()~>instHeaders
      when(ih~>libName=="tsmc18rf" && ih~>cellName=="nmos_3"
        dbSetInstHeaderMasterName(ih "bhvLib" "nmos" ih~>viewName)
    Best regards,
    Lawrence.
  • StephanWeber
    StephanWeber over 1 year ago in reply to skillUser
    Will try it!
    The idea is indeed to extend it for maybe 10 types of cells.
    Bye Stephan
  • StephanWeber
    StephanWeber over 1 year ago in reply to StephanWeber
    I open my schematic, and put this into CIW:
         when(ih~>libName=="devices_symbols_hv" && ih~>cellName=="pdomos50"
        dbSetInstHeaderMasterName(ih "bhvLib" “pmos_spectre" ih~>viewName)   ) )
    But nothing happens. So I need to press Control-C. Can you see a mistake?
    It would be also good to have a mapping from multiple target cells to a single final cell, e.g. we have different resistor types but I want to map to an (almost) ideal resistor.
    Bye Stephan
