  3. Layers list for creating symbol for PCELL
  • Subscribers 150
  • Views 4810
thiruvenkata
thiruvenkata over 1 year ago
I completed creating PCELL for layout, now I am trying to create a symbol for schematic instance for the pcell, I want to know what all layers are available in schematic, how can I check them?
    Andrew Beckett over 1 year ago in reply to RobMan +1
    This is also covered in the Schematic Editor Documentation: https://support.cadence.com/apex/techpubDocViewerPage?path=comphelp/comphelpIC23.1/chap13.html#customizingschematicobjectattributes Andrew
  • RobMan
    RobMan over 1 year ago
    The symbol uses pre-defined layers. Just create the shapes and pins using the symbol editor.
  • thiruvenkata
    thiruvenkata over 1 year ago in reply to RobMan
    I want to know what are those pre-defined layers, because I am creating it using code, so need to add them in layers section.
  • RobMan
    RobMan over 1 year ago in reply to thiruvenkata
    If you ok using SKILL then it's probably easier for you to open an existing symbol and interogate the objects.
    i.e. Select the shape then css()~>??
  • thiruvenkata
    thiruvenkata over 1 year ago in reply to Andrew Beckett
    Thank you!
    Thiru
