  3. bindkey for enterfunction
  • Views 4010
Albertyu
Albertyu over 1 year ago
hi all
i ocuur a problem that  i set a bindkey for a enterfunction like this hiSetBindKey("Layout" "<Btn3DownEF>" "WireMenu()"), the problem is if other scripts procedure has enterfunction that wiremenu will overlap all of them, so how could this wiremenu work only for this function, and dnot overlap other procedures which have enterfunction, when i click right button mouse.
thanks for your reply!
    A suggestion. In your code that uses the enter function, use something like:
    enterPoints(... ?cmdName "myWireCommand")
    and then in WireMenu() do:
    if(hiGetCurrentCmd()=="myWireCommand" then
       ; do all the work you want to do in this function
    else
       ; the previous bindkey callback for the Btn3Down in EF mode
      _lxHiMousePopUp()
    Note: I've not tested this, but I think it should work.
  • Albertyu
    Albertyu over 1 year ago in reply to Andrew Beckett
    thanks for reply, i will try it tomorrow. respect!
