  3. how to only print output (\o) and not the script (\i) lines...
  • Views 3698
how to only print output (\o) and not the script (\i) lines?
nmz787intel
nmz787intel over 1 year ago
when I run this code:
(defun nestedFunction ()
(printf "Inside nested function\n")
(exit(1))
(printf "This will not be printed\n")
(defun mainFunction ()
(printf "Inside main function\n")
(nestedFunction)
(printf "This will also not be printed\n")
if(errset({
(mainFunction)
} t) then
exit(0)
else
exit(1)
Using this cmd-line:
virtuoso -nographE -replay test.il -cdslib my.cds.lib -log my.log
I get output like this, which is driving me insane due to the "noise" of repeating the input I am feeding:
### license and version info I am skipping for brevity
\i (defun nestedFunction ()
\i (printf "Inside nested function\n")
\# [10:47:58.352074] Periodic Lic check successful
\# [10:47:58.352096] Feature usage summary:
\# [10:47:58.352096] 111
\# [10:47:58.352097] Virtuoso_Adv_Node_Framework
\i (exit(1))
\i (printf "This will not be printed\n")
\i )
\t nestedFunction
\p >
\i (defun mainFunction ()
\i (printf "Inside main function\n")
\i (nestedFunction)
\i (printf "This will also not be printed\n")
\i )
\t mainFunction
\p >
\i if(errset({
\i (mainFunction)
\i } t) then
\i exit(0)
\i else
\i exit(1)
\i )
\o Inside main function
\o Inside nested function
\e *Error* eval: not a function - exit(1)
\o
### license and memory info I am skipping for brevity
How do I disable printing \i input lines to the log file?
    The purpose of a log file from Virtuoso is to act as a transcript of the session, capturing all inputs and outputs. This allows the log file to be used for replay (via -replay - exactly what you're doing with your code). It's not really supposed to just be a convenient way of capturing some of the output. You could just open an output file yourself within the file you're replaying and print to that.
    So the answer is, no, you can't omit the input lines from a Virtuoso log file.
    However, another approach could be to do this:
    virtuoso -nographE -restore test.il -cdslib my.cds.lib -log my.log
    This outputs to standard out, and the my.log won't contain input lines because there were no input lines (you need to ensure that your script will always exit because otherwise it goes interactive).
