  3. Layer for cell name of symbol
  • Replies 7
  • Subscribers 150
  • Views 5656
thiruvenkata
thiruvenkata over 1 year ago
As I am creating a symbol for my PCell, I am not sure which layer should be used to display the cell name. Additionally, there is a "choice" section, but despite reading the documentation, I couldn't fully understand its purpose. What layer should be used, and what is the significance of the "choice" section? In my sample PDK symbols, the "choice" section displays "unknown." What does this mean?
  • RobMan
    RobMan over 1 year ago in reply to thiruvenkata +1
    And you didn't try my suggestion to investigate an existing symbol? As shown above... lpp ("device" "annotate")
    Andrew Beckett over 1 year ago in reply to thiruvenkata +1
    The layer-purpose that a label is on is not that important; you can find out what it is by selecting the label in the symbol editor and then using: car(geGetSelSet())~>lpp All that "unknown" means…
  • RobMan
    If creating through the UI the label "choice" will affect the layer according to schSymbolLabelChoices. Using SKILL (dbCreateLabel) you will need to assign the correct attributes to the object. This…
  • RobMan
    Is this not the same question you asked last week?
    Re. "choice". Are you referring to 'schSymbolLabelChoices'?
  • thiruvenkata
    thiruvenkata over 1 year ago in reply to RobMan
    Yeah RobMan, But I could only find layers for cdsTerm(), cdsName() and cdsParam() which are fixed, from documentation. But if I want to add cellName for my instance, what layer can be used? and what choice I need to use? These are my confusions, In some samples there is "unknown" as choice
    BELOW IMAGE SAMPLE PCELL's choice.
  • RobMan
  • thiruvenkata
    Yeah, it's working fine.
    Thank you.
    Can label choice be unknown? it's from one of the sample from other pdk.
    All that "unknown" means is that it's not in one of the predetermined choices covered by the variable schSymbolLabelChoices (type this in the CIW) that Rob mentioned earlier.
  • thiruvenkata
    thiruvenkata over 1 year ago in reply to Andrew Beckett
    Thank you Rob and Andrew for your answers.
    Thiru
  • RobMan
    This Article does it for a different label type, but should give you the gist...
    SKILL: How can I add the "NLPLabel" [@cellName] for all symbols in a library?
