  3. How to set parameter range for pcell by skill
  • Views 5107
TZ20240722725
TZ20240722725 over 1 year ago
I have created a pcell with some parameters for users to choose from. Now I want to add some restrictions on these parameters using skills (the width must not be less than 0 or greater than 30). How can I achieve this? This limitation is best reflected in the user interface, for example, if the user inputs a parameter that exceeds the limit of 35, the skill can directly pull the input back to 30 on the interface (rather than just reflecting it in the pcell).
  • RobMan
    RobMan over 1 year ago
    You would do this as part of the CDF. Create a callback to check for valid range and correct (with user notification if desired).
    See....
    Virtuoso Parameterized Cell Reference
    Component Description Format User Guide
  • TZ20240722725
    TZ20240722725 over 1 year ago in reply to RobMan
    thank you a lot.I use the function cdfDump, but export a nil file.what`s happened?if i use the function to the library Self-contained pcell, it return a file with cdf information;but if i use this function to the pcell i write by myself, it only return a nil file.
  • RobMan
    RobMan over 1 year ago in reply to TZ20240722725
    Did you create any CDF for your cell?
    Re. Virtuoso Parameterized Cell Reference (again)
    PCell Generation Tutorial: Quick Reference to Basic Concepts and Frequently Referred Solutions
    Component Description Format User Guide -- Introduction to Component Description Format (CDF)
  • TZ20240722725
    thank you! i need to use function"cdfCreateBaseCellCDF"  first to create a cdf,and i can open cdf or use "cdfCreateParam" to edit it
  • RobMan
    Yes; create base cell CDF is a good starting point. Then add as appropriate.
