  3. Setting up layout display options in cdsenv
  • Subscribers 150
  • Views 5747
dakuang01
dakuang01 over 1 year ago
Hi there,
I would like to turn on "Label Origins", "Enable Dimming", eipSurround for the Dimming scop by default.
I got these commands by Log Filter and it didn't work on .cdsinit.
leDisplayOptionsForm->options->labelOrigins->value = t
leDisplayOptionsForm->enableDimming->value= t
leDisplayOptionsForm->dimmingScope->value="eipSurround"
I also tried these in .cdsenv and it didn't work either.
layout labelOrigins boolean t
layout enableDimming boolean t
layout dimmingScope "eipSurround"
How can I set these as default?
Jane
  • RobMan
    RobMan over 1 year ago +1
    You need to check the correct envar corresponding to the form setting. layout textJustificationOn boolean t layout dimmingOn boolean t layout dimmingScope string "eipSurround"
  • RobMan
    RobMan over 1 year ago in reply to dakuang01 +1
    Virtuoso Layout Suite XL: Basic Editing User Guide -- Display Options Form Other resources which can help: CIW -> Options Cdsenv Editor Editor: Search Assistant CIW -> Options -> Save De…
  • RobMan
  • RobMan
    RobMan over 1 year ago in reply to RobMan
    FYI The above is .cdsenv format. .cdsinit requires envSetVal (check docs for syntax).
  • dakuang01
    dakuang01 over 1 year ago in reply to RobMan
    Thank you very much for the commands, RobMan. It works!
    How can I get the correct envar?
    The only thing I know is I can see the command line when you turn on \a(Accelerated input) in Log Filter of CIW.
  • RobMan
    CIW -> Options -> Save Defaults
  • dakuang01
    Thank you so much RobMan! Slight smile
