  3. Need help on below case
  • Views 3812
aryansingh
aryansingh over 1 year ago
Hi All,
I am new to skill & learning so i will be sharing a testcase that i came across....,
Initially, I am saving a path of text file in a variable in skill
Let's suppose
text="/home/dec/text.tx"
Now I want to search Master keyword in this text file & saving it in different variable by help of
cid1 = ipcBeginProcess("grep 'Matser' text")
ipcWait(cid1)
layerMap1 = ipcReadProcess(cid1)
But i am getiing final result as layerMap1=\n
I am able to identify that it is not able to take the path of text file because of double quotation.
Now i am not able to come on a conclusion that how should i provide path as a variable for searching a pattern in that because when i am manually putting path able to get the result.
Thanks & Regards
Aryan
    cid1 = ipcBeginProcess(lsprintf("grep 'Master' %s" text))
    ipcWait(cid1)
    or
    cid1 = ipcBeginProcess(strcat("grep 'Master' " text))
    ipcWait(cid1)
    Of course, I fixed the "Matser" typo in your code too.
  • aryansingh
    aryansingh over 1 year ago in reply to Andrew Beckett
    Thank you so much Andrew for your help !
