  3. Trying to reduce the runtime of a skill code : viaGenerateViasInArea...
  • Subscribers 150
  • Views 5127
Trying to reduce the runtime of a skill code : viaGenerateViasInArea, dbCreateRect or dbDeleteObject
dakuang01
dakuang01 over 1 year ago
Dear all,
I put a part of my skill codes.
I used the function viaGenerateViasInArea for the first time to create stacked vias. I am supposed to select only via objects in the layout view, so I ended up creating the bottom metal and the top metal to make the function work and then deleted them after generating the vias.
The response time of my function is too long at the moment so I'm trying to investigate what is causing it. First, I wanted to try turning off the prints showing on CIW of viaGenerateViasInArea as the info. I got from the Forum.
When the two below options are both nil on CIW, the results are still printed. How can I turn off all reports? And when I put the two lines in my skill code, the options don't change like you do on CIW. Am I missing anything here?
myViaOptions->automatic->printStatisticsReport=nil
myViaOptions->automatic->printStatisticsReportByStackDepth=nil
Maybe the two functions dbCreateRect and dbDeleteObject take long to be executed. Hope my question is clear and any answer is welcome.
constraintGroupId = cstFindConstraintGroupIn(techfile "virtuosoDefaultSetup")
myViaOptions = viaGetViaOptions(constraintGroupId)
myViaOptions~>createInRoute = nil
l_topBottom = list(t_botMT t_topMT)
d_botMT = dbCreateRect(cvId list(t_botMT "drawing") l_bBox) ;Create lowest metal
d_topMT = dbCreateRect(cvId list(t_topMT "drawing") l_bBox) ;Create highest metal
d_viaFig = viaGenerateViasInArea(cvId l_points myViaOptions ?topAndBottomLayers l_topBottom)
geSelectFigs(d_viaFig)
dbDeleteObject(d_botMT)
dbDeleteObject(d_topMT)
< Test on CIW >
myViaOptions->automatic->printStatisticsReportByStackDepth~>?
nil
(VIA-1010): Running the auto via command in area (-5.39, -5.49) (-5.39, -4.57) (-2.87, -5.49) (-2.87, -4.57).
* Auto Via Statistics *
* Area : (-5.39, -5.49) (-5.39, -4.57) (-2.87, -4.57) (-2.87, -5.49) *
* Run Time = 0.01 sec [cpu: 0.01 sec] *
* Total number of vias created: 3 *
# Summary
| Stack | Metal Overlaps | Via | Initial Overlaps | Final Results | Percent |
| Depth | Bottom - Top | | Total | Unconnected | Newly Connected | Connected | |
| 3 | M1 - M4 | V1 - V3 | 1 | 1 | 1 | 1 | 0 -> 100 |
| Totals | 1 | 1 | 1 | 1 | 0 -> 100 |
myViaOptions->automatic->printStatisticsReport~>?
nil
Jane
    Andrew Beckett over 1 year ago +1
    Jane, This works for me. I do not see the statistics being printed with your code. Which IC sub-version are you using? I rather doubt that avoiding printing the statistics will take any significant…
    Jane,
    1. Which IC sub-version are you using?
    2. I rather doubt that avoiding printing the statistics will take any significant time
    3. The run time shown in the statistics above is rather short (0.01 seconds)
    4. Creating two rectangles and deleting them are not going to take any appreciable  amount of time either
    What sort of "response time" are you seeing?
  • dakuang01
    dakuang01 over 1 year ago in reply to Andrew Beckett
    Andrew,
    Thank you for your reply. Good to see all your confirmation of #2 thru #4.
    I'll restart my Cadence and see if it works.
    To answer your question, I'm on ICADVM20.1-64b.500.32
    I have a bindkey for the function. When executing the function by it, the top via is generated instantaneously, but the lower vias take up to 2 seconds to be created. That's why I was looking at the three functions.
    Jane
  • dakuang01
    I'm just wondering if you see the same delay.
    Jane
