  3. How to adjust the precision at the 45° path routing?
  • Views 3153
TZ20240722725
TZ20240722725 over 1 year ago
I want to use SKILL to generate a Pcell, and 45° routing is used in the Pcell. Due to the limitations of the process library, the layout precision cannot be less than 0.005. However, the 45° routing inevitably generates points with a precision of 0.001 at the corners. Is there any way to reduce the precision to 0.005 without compromising the 45° routing? For example, can this be set from the rodCreatePath function or something similar?
