  3. Loading Pcell into virtuoso
  • Views 6860
AE202502048334
AE202502048334 over 1 year ago
I have created a PCell for metal tracks using skill.
The code relies on a having a created cell with a specific name and library so it can generate the shapes inside it and I checked in this view.
I have string / float inputs to control metal tracks number and widths, also switches to control the appearing or disappearing of some layers (cut layers for poly and MD).
When I first load the code it works very well no issues and create my pcell just fine and the switches and inputs work. I instantiated it in a layout view called "test".
The issue
when I restart virtuoso, the "test" view gives me pcell evaluation failed as it needs to load the script every time, so I added the "load script line" in libinit.il file of the library containing the pcell view, now each time I reload virtuoso it prompts me to check out the pcell view and I choose "NO", now I open the "test" view to find only the metal tracks shapes are there but all other shapes are not there (all these shapes rely on the ON/OFF switches that I have in my pcell)
The code controlling these shapes are if statements and logic written inside pcell main body (I don't use callbacks)
I believe this behavior is normal as I redefine the cell each time I open virtuoso so it sort of resets all my switch values, The question here how to avoid the "pcell evaluation failed" message, or what is the right part of code to have it written in libinit.il file to define my pcell without rerunning the code again and resetting everything.
Thanks in advance
    Andrew Beckett over 1 year ago +1
    You should not call pcDefinePCell from within the libInit.il . You would however need to define any custom functions used within the pcDefinePCell because otherwise those will not be available. I suggest…
    You should not call pcDefinePCell from within the libInit.il . You would however need to define any custom functions used within the pcDefinePCell because otherwise those will not be available. I suggest (if it's all in one file) doing something like this:
    procedure(MyAuxilliaryFunc(x y z)
      ; do something
    procedure(MyDefinePCell()
      pcDefinePCell(
        list(ddGetObj("libName") "cellName" "layout")
        ; formal params
        ; body of the PCell - does the work and probably
        ; calls your other custom functions
        MyAuxilliaryFunc(e f g)
    Loading all this would be fine. You only then need to define the PCell once, by calling MyDefinePCell() - the code in the body of the pcDefinePCell will be stored in the layout view  (or whatever view you're creating) and does not need to be defined again. The auxiliary functions will be loaded each time by virtue of the libInit.il
  • AE202502048334
    AE202502048334 over 1 year ago in reply to Andrew Beckett
    Thank you Andrew, Will apply this structure
  • AE202502048334
    I wanted to make sure of my understanding as now I have the Pcell evaluation issue.
    My main Pcell code which I load in CIW is just load 5 files as follows:
    ;Defining Global Parameters
    load("Global_Parameters.il")
    ; Defining CDF Parameters
    load("CDF_Parameters.il")
    ; Defining PCELL Default Variables Definitions
    load("PCELL_Default_Variable.il")
    ; Defining Routing PCELL
    load("Routing_PCELL.il")
    ; Defining Custom Procedures
    load("Procedures.il")
    Global_Parameters.il is just some fixed values
    The main focus here will be on Routing_PCELL.il, Procedures.il & CDF_Parameters.il.
    here I have a small sample of the code:
    Routing_PCELL.il is as follows:
    ___________________Pcell Definition Section__________________
    pcDefinePCell(
    ; Cell Identifier
    cellIdentifier
    ;Formal Arguments : Default-Values
    (fingers default_fingers)
    (polyPitch default_PolyPitch)
    (cellHight default_cellHight)
    ; Main
    let(()
    createPR()
    );end of let function
    );end of pcell definition function
    Procedures.il is as follows:
    procedure(createPR()
    fingers = cdfgData~>fingers~>value
    polyPitch = cdfgData~>polyPitch~>value
    cellHight = cdfgData~>cellHight~>value
    rodCreateRect(
    ?layer list("prBoundary" "boundary")
    ?width fingers*polyPitch
    ?length cellHight
    ?origin list(0 0)
    CDF_Parameters.il is as follows:
    let( (cellId cdfId)
    when(cellId = ddGetObj("M0_PCELL_v2" "M0_PCELL_v2")
    when(cdfId = cdfGetBaseCellCDF(cellId)
    cdfDeleteCDF(cdfId)
    cdfId = cdfCreateBaseCellCDF(cellId)
    ________________________________________Poly Pitch________________________________________
    cdfCreateParam( cdfId
    ?name "polyPitch"
    ?prompt "Poly Pitch"
    ?defValue 0.048
    ?type "float"
    ________________________________________Cell Height________________________________________
    ?name "cellHight"
    ?prompt "Cell Height"
    ?defValue 0.208
    ?type "float"
    ________________________________________Number of Fingers__________________________________
    ?name "fingers"
    ?prompt "Number of fingers"
    ?defValue 1
    ?type int
    Regarding libInit.il file I have loaded ("Procedures.il") inside it
    Andrew Beckett over 1 year ago in reply to AE202502048334
    OK, first of all, you should not load CDF_Parameters.il or Routing_PCELL.il from the libInit.il. I'm not sure what's in Global_Parameters.il or PCELL_Default_Variable.il - maybe these are needed to be loaded too?
    In addition, the code in Procedures.il is not going to work. Rather than taking the Pcell parameters directly, it is getting them from cdfgData. That won't work - it might work whilst you are instantiating, but won't work if you re-open the design. cdfgData is only set during the create instance or edit properties form, and is the wrong way to communicate to the PCell code. Instead, your function should be something like:
    procedure(createPR(fingers polyPitch cellHight)
    ;  fingers = cdfgData~>fingers~>value
    ;  polyPitch = cdfgData~>polyPitch~>value
    ;  cellHight = cdfgData~>cellHight~>value
      rodCreateRect(
        ?width fingers = fingers*polyPitch
        ?length cellHight
        ?origin list(0 0)
    and then in the PCell definition code you should have:
    pcDefinePCell(
      ; Cell Identifier
      cellIdentifier
      ; Main
      let(()
    In other words, pass the variables from your PCell into your construction function. The CDF is just a means of causing the parameters to be set on the instance, and to control what the form looks like - the PCell code should not be trying to refer to the CDF.
  • AE202502048334
    Thank you so much for your continuous support.
    Maybe for a future reference for anyone, I was using check box switch and trying to pass it's value to the my construction functions but it was a big issue, now I used radio button and the structure you guided me to, and it's working fine.
    Thank you so much andrew.
    Regards.
    Ali
