  3. Tech.db generation
  • Views 3816
Tech.db generation
aryansingh
aryansingh over 1 year ago
Hi All, I am trying to generate tech.db file for a cellset for which I am taking inputs from lef for every sitedefinition that is present.
I am able to dump the data in a textfile like below
; REFERENCED TECH LIBRARIES
controls(
refTechLibs( "tsmcN16" )
; SITE DEFINITIONS
siteDefs(
scalarSiteDefs(
;( siteDefName type width height symInX symInY symInR90 )
( core9t_2h core 0.096 0.96 t nil nil )
( core9t_2h core 0.096 0.96 nil t nil )
( core9t_2h core 0.096 0.96 t t nil )
( sc9mcpp96c_cln16fcll001 core 0.096 0.48 t t nil )
But not able to append the this data in tech,db file as when i am dumping the data from virtuoso itself it is only dumping this data
; Technology File LOG_A7P5TM2PP96_PD_SPECIAL
; Generated on Mar 12 15:18:23 2025
; with @(#)$CDS: virtuoso version IC23.1-64b 01/09/2024 22:32 (cpgbld15) $
; CONTROLS
controls(
techVersion("1.0")
refTechLibs(
; techLibName
"tsmcN16"
) ;refTechLibs
) ;controls
; LAYER DEFINITION
layerDefinitions(
) ;layerDefinitions
; SITEDEFS
siteDefs(
scalarSiteDefs(
;( siteDefName type width height symInX symInY symInR90)
( core9t_2h core 0.096 0.96 t t nil)
) ;scalarSiteDefs
) ;siteDefs
Can anyone help me out regarding this issue ?
    Each siteDefName needs to be unique (as far as I am aware). I think the same is true of SITE names in LEF. I suspect that something in whatever did the conversion of the LEF into a tech database in the first place didn't honour that which is why you are seeing duplicates.
    I'm not an expert on this, but this is my reading of what's going on and the documentation. You might want to contact http://ask.cadence.com and then submit a support case from the Case menu after logging in to understand how your original tech database ended up with the duplicates siteDefNames in the first place (and to confirm whether my understanding is correct or not).
