  3. Edit cut pattern of via
  • Subscribers 150
  • Views 4328
mattab
mattab over 1 year ago
I wish to  edit cut pattern of via and change Patterns from Farm-->All on. Please help me do it in skill
    See How can I modify the cut pattern of a via using SKILL?
  • mattab
    mattab over 1 year ago in reply to Andrew Beckett
    Thanks Andrew! Can you help me with another one, while I do autovia default edit pattern is Farm .Is it possible to change it to all on in .cdsenv ,I am not finding it in .cdsenv
    Andrew Beckett over 1 year ago in reply to mattab
    This happens if there is a minLargeViaArraySpacing constraint in the tech file. I don't know of a way of changing the default from Farm if that's in the tech file - I suggest you contact customer support.
  • mattab
    Thank you ,I will check  it
