  3. Schematic Pcell to create a new version from another sc...
  • Views 4144
Schematic Pcell to create a new version from another schematic
JD202503261844
JD202503261844 over 1 year ago
Looking for some skill code to generate a  schematic pcell that is based on a existing schematic but that some of its parameters will be change.  The static schematic will provide the topology of the cell, and the  might change certain parameter device parameters like model, w or l based on input paramters. It should be a fairly common request since it can be use to generate w,l,m parameteried gates.
  • AaronSymko
    AaronSymko over 1 year ago
    A better way to do this would be to simply use pPar() expressions for the instance parameters that you want to vary, and then expose those through CDF parameters for the cell.  This would avoid the need to use pcells and/or any SKILL coding.
  • JD202503261844
    JD202503261844 over 1 year ago in reply to AaronSymko
    Thanks Aaron.  I thought about the pPar method, but one of the reasons for the pcell approach is there might be actual changes done to the  initial schematic based on parameters.   The topology of the cell might change slightly so the ppar approach wont be enough.
  • skillUser
    skillUser over 1 year ago in reply to JD202503261844
    if you need to change the connectivity/topology of the schematic then you either need to (re)create the entire schematic as a PCell, or you might use code to alter an existing schematic to make a variant (if you will not have too many variants, or don't need to do this too often).  You can get help in writing the PCell code for the schematic by using the 'dbWriteSkill()' function to dump out an existing schematic as code, however this will not be efficient for the actual PCell code, you would re-write the code to parameterize it and improve it (e.g. grouping like statements for creating instances and objects).
    There is also the PCell Designer tool (additionally licensed from Cadence) - you would need to reach out to Cadence for more details.
    Best regards,
    Lawrence.
