  3. bindkey for check->find marker
  • Views 1207
IW202412053139
IW202412053139 over 1 year ago
After check and save in schematic, is there a bindkey for check-> find marker? I need to do this so many times and it is kind of a pain to use drop down menu. If there is a skill code on this please let me know thank you.
    In the default bind keys, this is bound to the key "G" (if you look at the Check menu it should show the bindkey to the right of "Find Marker"). If that's not there, something else must have been bound to the G key in your environment.
    You can define a bindkey using:
    hiSetBindKey( "Schematics" "<Key>G" "schHiFindMarker()")
    You could find the function simply by using Options→Log Filter in the CIW and and then turning on the "a" Accelerated Input checkbox and then choosing the menu to see what function is called.
  • IW202412053139
    IW202412053139 over 1 year ago in reply to Andrew Beckett
    Yes it was overwritten in my bindkey file. Thanks.
