  3. how can I use the delay function to measure the delays between...
  • Subscribers 152
  • Views 5261
how can I use the delay function to measure the delays between the closest rising edge of a singal_A and the following rising edge if signal_B
MFahmy
MFahmy over 1 year ago
I am trying to use the delay function to measure the delays between a rising edge of a singal_A and the following rising edge if signal_B,
Signal_A is a periodic signal (clock) , while signal_B is a random bit stream,
The delay function uses every rising edge from signal_A as a measurement event which is inaccurate in this case, what I am looking for is to measure the delay from the current rising edge of Signal_A to the current rising edge on signal_B and the current edge of a given signal is the latest edge, in other words, measuring the closest rising edge of signal_A to the next edge of signal_B
The triggeredDelay function works by measuring a triggering event to a rising edge after it, which also does not serve the purpose, (Tperiod - Triggered delay) can be used as a work around, but it is inaccurate as the clock signal has jitter
Fahmy
virtuoso version IC23.1-64b
sub-version  IC23.1-64b.ISR13.25
  • Dung Nguyen
    Dung Nguyen over 1 year ago
    Given a case that you are trying to measure the hold time of a flip-flop with periodic clock and random data.
    My previous experience on this is to combine triggeredDelay and rshift. Basically, the idea is to right-shift clock signal with delta X being equal to period, then using triggeredDelay to measure setup time of data compared to shifted-clock. Last step is to subtract your 'calculated setup' from Tperiod to get 'real hold'.
    Ex: (2*VAR("UI")) - ymax(triggeredDelay(clip(VT(din), tc_start, tc_stop) rshift(clk_diff (2*VAR("UI"))) (VAR("vddavs") / 2) "either" 0 "falling"))
    However, a more compatible function has been defined by Cadence:
    support.cadence.com/.../ArticleAttachmentPortal
